Hinges for an inset overlay panel
9/17/23
Kevin Member
Is there a type of hinge that can be used for an inset panel that has an overlay? To picture this imagine a piece of drywall patch being installed over two scabbed 2x4's that will support the drywall and allow it to sit flush with the adjacent drywall. Instead of screwing the drywall to the 2x4's it should be hinged from one side of the 2x4's.
9/18/23       #2: Hinges for an inset overlay panel ...
BH Davis  Member
Is this what you are trying to describe?
View higher quality, full size image (823 X 462)
9/18/23       #4: Hinges for an inset overlay panel ...
Kevin Member
Thank you, BH! Yes, that is exactly the scenario I was trying to describe. note... I would like the drywall faces to align flush, exactly as you have depicted in your drawing.
9/18/23       #5: Hinges for an inset overlay panel ...
Leo G
You plan on hinging drywall?
9/19/23       #6: Hinges for an inset overlay panel ...
Kevin Member
If possible, if not other options are on the table
9/19/23       #7: Hinges for an inset overlay panel ...
BH Davis  Member
Knowing there are always exceptions to everything I will go ahead anyway and say: you can't hinge drywall.....chuckle.
How about 1/2" plywood with a Durabond skim coat?
Of course this doesn't answer your question about the hinges. I'm not sure what is out there that might work. I'd suggest a detailed study of the Grass, Amerock, Salice etc. catalogs.
9/20/23       #8: Hinges for an inset overlay panel ...
Pat Gilbert Member
Where is the laugh emoji
9/24/23       #9: Hinges for an inset overlay panel ...
Mark B
Hinge a plywood panel with a standard flush inset hinge (off the shelf) and apply a 1/4" drywall skin (mastic'd to the plywood panel). You'll have to account for the total door thickness, perhaps 7/8" in your hinge selection (1/2" ply, mastic, 1/4" drywall likely with some sort of Jbead around the perimeter.
I dont see the need for the drywall as any smooth door material (MDF) will paint up like drywall and be far more durable face for a swinging door.
    • J&P Machines
    • CabMaster Software
    • Lignomat
