Vertical panel saw blades
11/13/23
Tom
Any suggestions on blades for cutting melamine on a holzher 1205 vertical panel saw.
11/14/23       #2: Vertical panel saw blades ...
Bruce H
I use a hollow grind from Leitz. The issue you are going to have is getting them sharpened correctly.
11/14/23       #3: Vertical panel saw blades ...
I use the same blades as Bruce
11/20/23       #4: Vertical panel saw blades ...
Superclw Member
Website: https://www.superclw.com/
Number of teeth and tooth type: Select the appropriate number of teeth and tooth type to improve cutting efficiency and reduce saw marks. For melamine boards, it is recommended to use a blade with 40-60 teeth. The tooth type can be selected with staggered teeth or flat teeth, according to the cutting requirements and plate characteristics
    • The Millwork Studio
    • Lignomat
    • O'Shea Lumber Company
      Merchants of Fine Woods
    • TradeJobPlacement.com
