Widebelt Sander Tracking
1/5/24
Jim Herron
I have a SCMI 37" two head widebelt sander that I'm considering converting from air tracking (air hog plus problems tracking the belts) to photoelectric switch and air direction control valve, using the 24 volt in the sander
Would both heads be controlled (oscillating in unison) with one switch and a single dual port control valve or would it require a switch and valve for each head?
I've never converted one so maybe someone can chine in here
1/5/24       #2: Widebelt Sander Tracking ...
I can't imagine any good coming from just one control system. You anticipate both heads being in complete unison all the time? Personally I see that as a rare thing.
1/5/24       #3: Widebelt Sander Tracking ...
Jim Herron
So two photoelectric switches and two air direction valves required.
Makes sense but wasn't sure.
1/6/24       #4: Widebelt Sander Tracking ...
How old is your sander, I thought the SCM’s already had the photo cels on them?
1/19/24       #5: Widebelt Sander Tracking ...
Jim Herron
Update
Was able to hustle up a 24 volt power supply, photoelectric sensors wirh reflectors, relays, and pneumatic valves and tubing
Installation took most of the day but not difficult and satisfied with the end results
No more constant air drain and worth every penny, just wish I'd done it when I bought the sander 15yrs ago
    • Original Saw Company
      Industrial Radial Arm Saws
    • Country Saw & Knife
    • GreCon
    • Steve H. Wall Lumber Co.
