Advice Please!
1/7/24
Jon Member
I build frameless cabinets and use Blum press in hinges (110*) normally….on a few occasions I will have a sink unit with a false front above 2 doors at bottom….i will have to adjust the hinges so much, in order for the door to close properly, that on the hinge side the door sticks out more than the false front does….meaning the false front and the doors are not plumb with each other… in other words there is a gap between door (on hinge side) and the cabinet, however if I adjust the hinge and close that gap, the door will not close all the way against cabinet on opposite side of hinges… the hinges are press in hinges and they are all the way in ! I included some photos to show my style of cabinets.. the small vanity is one I’m having issues with, although it’s hard to tell in photo…What’s going on?? Thank you guys so much, I look forward to hearing your responses!!
1/7/24       #2: Advice Please! ...
Matt Calnen
There is always a gap between the face of the box and the back of the door, usually a 1/16” to an 1/8”. The hinge needs it for clearance. Pack your dummy drawer front out with the same bumpers you use on the pull side of the door. Looks like you did not make your dummy drawer front wide enough either, as the doors stick out beyond the sides of it.
1/8/24       #5: Advice Please! ...
Oggie  Member
You either make your doors narrower or your false drawer front wider.
Start with the width of your cabinet case (left to right), subtract the gap you want to have from the edge of your case to the edge of your door (usually 1/16"), the gap between doors in the middle of the cabinet (usually 1/8") and the gap on the opposite side (usually 1/16", i.e. same as on the other side). Divide that by 2 and that is how wide your doors need to be.
Door_width = (Cabinet_width - 1/16" - 1/8" - 1/16") / 2
False_drawer_front_width = Cabinet_width - 1/16" - 1/16"
Also, depending how thick is the panel you use for your cases, you may want to check Blum installation manual for the hinge you are using to find out how far from the door edge the hinge hole should be drilled (5, 6, 7mm....).
1/9/24       #6: Advice Please! ...
brent
Like matt said there is always a gap. Blum compact hinges have a lot bigger gap than clip top hinges. So go with clip top if you want less gap in general.
It sounds like the issue you are having is from a door or cab that might not be flat. So you have to adjust the hinges in or out to make up the difference, then it will close at the top of the door. The best way is to swap the doors to other side of the cabinet before you drill for the pulls. Then the gap will be on the bottom. Since you have drilled for pulls already I have had luck taking the door off and clamping the door to a table opposite the way its racked and leave overnight. Sometimes wood will twist and rack a door after its built. But maybe this isn't the issue you are having.
1/10/24       #7: Advice Please! ...
Bruce H
if your cabinet is twisted when installed you will have issues and need to adjust your hinges. Make sure the cabinet is plum and level. As for the gap behind the door, get rid of the compact hinges and use a normal Blum hinge that allow for in and out adjustments. Put bumper pads behind your false front.
2/3/24       #8: Advice Please! ...
Trey Thompson  Member
Website: http://www.cooperandelm.com
We were having the same issue with false fronts. It was pretty easily solved by shimming the false front out a bit somewhere between 1/16 to 1/8 of an inch.
I would second the use of bumpers as an easy method to get the false fronts to be flush with doors, but there are a few different ways to do it.
    • RT Machine Co.
    • Original Saw Company
      Industrial Radial Arm Saws
    • Lignomat
