Scm K208 edgbander
1/14/24
Bob Connor’s Member
I have SCM K208 auto edge bander that is not feeding 3mm pvc banding. The drive pin/spinning shaft that pulls the tape spins when conveyor is moving but not touching the tape. Does this drive pin/shaft supposed to move toward banding when trigger by work piece
1/16/24       #2: Scm K208 edgbander ...
Fred
Hi Bob,
You should see a sensor with a spring loaded bearing, close to the glue applicator. As the board that gets banded passes the sensor gets lifted and the feed roller moves and catches the banding. There should be another sensor like it just past the guillotine and it triggers the knife and makes the feed wheel move back.
If the Sensor at the Guillotine was not triggered the fist sensor wont work.
    • J&P Machines
    • CabMaster Software
    • Lignomat
