blum mini press
2/5/24
RON Member
I have a older blum mini press M51n1053. Went to use it today and it wont cycle down. Looking for suggestions or if there is any one that works on them in the Midwest
Ron
2/5/24       #2: blum mini press ...
Jim Herron
Is it not responding to electrical input (start button or relay to activate pneumatic and motor) or is it leaking air (motor runs but no cycle of pneumatic piston) ?
2/6/24       #3: blum mini press ...
RON Member
When I push the start button the motor kicks on runs a little then turns off
2/6/24       #5: blum mini press ...
Jim Herron
See if you can clean the relay, power off, with a liberal spray of electric contact cleaner or see if the pneumatic actuator is sticking
