1997 Holzher Genesis 1435 SE troubleshooting F1 glue temp error
2/26/24
Thomas Dougekos Member
Yesterday the 1st glue temp control showed F1 fault and shut off,
Any ideas as to what I should look for would be greatly appreciated.
also, any advise as to how to remove the thermocouple temperature sensor from the glue head, it seems to be seized in the glue head.
Thank you
2/26/24       #2: 1997 Holzher Genesis 1435 SE troubl ...
Problem solved, simple connection issue with the temperature sensor to the temp control.
Thank you Ed at Holzher and Gordon Pettit
    • Original Saw Company
      Industrial Radial Arm Saws
    • Country Saw & Knife
    • GreCon
    • Steve H. Wall Lumber Co.
