Blum minipress issues
2/29/24
Nathan Member
Hi there,
My shop has a Blum minipress that doesn't seem to want to spin. I can get it to go by "kickstarting" it. But even with that it's a slow start. I've checked the power and it's on, it will go down and up no problem.
I assume is the motor but I don't know what my next step should be
Any help would be appreciated, thank you.
View higher quality, full size image (4080 X 3072)
2/29/24       #2: Blum minipress issues ...
Stuart douglas
Have you checked the clutch? White disk in the drive head with dogs on it. Probably worn out.
2/29/24       #3: Blum minipress issues ...
nathan Member
I will check for that, thanks. I also noticed that someone had moved it (it's on a table with wheels) and set it under a small cabinet and when a coworker turned the air on the machine lurched up and bent what I think is a capacitor (a silver cylinder attached to a wire). He even broke the cabinet and didn't notice.
View higher quality, full size image (3072 X 4080)
2/29/24       #4: Blum minipress issues ...
Stuart douglas
YIKES!
3/3/24       #6: Blum minipress issues ...
Jon Member
From the tag on the motor, it looks like it is single phase, so I would definitely say that the capacitor would be my first thing to check out.
