mini press won't go down while drill spins
3/23/24
Angelon
hey folks, the issue im having is that when in setup the press goes down but when i switch to drill it will only spin but wont go down. any ideas what the issues could be?
3/23/24       #2: mini press won't go down while dril ...
Could you possibly share what model and make of machine you are asking about?
3/24/24       #3: mini press won't go down while dril ...
Jon Member
Since it goes down when the knob is in set up position, I would guess it has something to do with how the valve is energized when the knob is switched to the drill position. Maybe it is in the switch??
    • Original Saw Company
      Industrial Radial Arm Saws
    • Country Saw & Knife
    • GreCon
    • Steve H. Wall Lumber Co.
