Inset face frame hinge problem
4/2/24
Liz
Hi,
I'm building a face framed inset door cabinet. I bought Blum 110° Clip Top Face Frame hinges, part number 77B83. Once installed, they open perfectly. However, when closing the doors, they swing inward about an inch into the actual cabinet interior, past the face frame. I'm new to this type of woodworking, and would appreciate any help or insight on how to stop the inward swing and have the doors flush with the cabinet face. The doors and face frame are the same depth, and I alloted for a 3/32 gap on all edges.
Thanks for any help!
4/2/24       #2: Inset face frame hinge problem ...
Jim Herron
The hinge mounting plates should be set back 37mm minus your door thickness
4/3/24       #3: Inset face frame hinge problem ...
Adam B Member
I think Liz is saying that the non hinged side of the door is closing into the opening. If that is the case, you will need to add some sort of "stop" so that the door stops closing when it is flush wit your frame.
4/3/24       #4: Inset face frame hinge problem ...
Hello Liz,
All European hinges are made to "over close" a bit. This is to keep the door closed tight to the frame or cabinet side with overlay doors. This is completely normal.
As mentioned above, you will need something to stop the door when it is even with the frame.
There are a few ways this is traditionally done.
(1) Attach a block of wood behind the frame making sure it drops down below the frame to act as a stop.
(2) For appearance's sake, many cabinet makers will install a strip of wood that runs completely from left to right, behind the frame. Again, it will drop down below the frame to create that stop that you need.
(3) A cool trick for this is to use 2 whole earth magnets. One in the frame and the other in the door's top edge. When they are bypassing each other, the magnets grab each other, and this prevents the door from over closing.
(4) The simplest way to fix this is to use the inset door stop made by Fast Cap hardware. This is a small black rubber disc that can be attached to the top and bottom of the opening to stop the door from over closing. It is adjustable via eccentric holes.
There are several other brands of door stops. Just go to the supplier where you purchased the hinges and search: Door stop for inset doors.
Here is a link to the fast cap product that I mentioned.
Best of luck
Dennis Bean
Salice America
Fastcap Doorstop
4/3/24       #5: Inset face frame hinge problem ...
These
Inset stops
4/4/24       #6: Inset face frame hinge problem ...
Hi Leo,
Another good choice.
Dennis
4/4/24       #7: Inset face frame hinge problem ...
It's what I've been using for a decade now. I don't think the one's I get are Hafele as I get them from a local supplier. But they are the same. On occasion I've had to cut off one hole or bend them to get the desired result in some oddball situations.
So much better than wood blocks.
4/4/24       #8: Inset face frame hinge problem ...
I posted the link to Woodworkers Hardware for the Fast Cap discs since Liz seems new to cabinet making and likely doesn't have an account with Hafele or other traditional distributors. Woodworkers Hardware is a great retail source for the occasional onesie/twosie buyer.
4/4/24       #9: Inset face frame hinge problem ...
I was shocked I couldn't find them on Amazon. They are in a few places other than Hafele if you search.
4/4/24       #10: Inset face frame hinge problem ...
duster
I just make a stop with a little scrap and glue & screw it to the back of the face frame or side of the cabinet. Takes maybe 2 or 3 minutes and I don't have to buy anything.
4/8/24       #11: Inset face frame hinge problem ...
Joshua Member
Website: https://wattsan.com/
Blum 110° Clip Top Face Frame hinges are adjustable to allow you to customize the position of your doors. They usually have adjustment screws on the hinges that allow you to raise or lower the doors. Try adjusting these screws
4/10/24       #12: Inset face frame hinge problem ...
Jim Kolar
Sounds like you are looking for a stop block. When we do inset we rip in our lineal faces frames an additional lineal of 3/4 x 1 1/4 for stop block. We have a router table set up that rabbet a strong 1/16" x 1/2". Door bumper thickness. This gets nailed on when cabinet is finished sanded and doors are ready to install.
    • Original Saw Company
      Industrial Radial Arm Saws
    • Country Saw & Knife
    • GreCon
    • Steve H. Wall Lumber Co.
