Panel Genie
Pass thru door alignment
6/5/24
Robert
I have a situation where we built a pass thru type cabinet with 2 relatively long doors (75") for entry into a small closet. They are maple with 2 mdf flat panels and a center rail, finished with cv. They do not seem to have any noticeable twist-except for the fact one of them dives in at the bottom. Won't align with the other door, which does close on plane at the bottom. The budget wouldn't allow for expensive hinges such as Soss (?) and we did mention this possibility. Since the cat is already out of the bag, I'm looking for suggestions for keeping the errant door in line with the correct one.
I've thought about a backing strip (probably should've anyway maybe), or a bullet catch, or possibly magnets somehow? Any help would be appreciated. Thank you all.
6/5/24       #2: Pass thru door alignment ...
Matt Calnen
A picture or drawing would help me understand a lot better. What exactly is a “dive”?
6/6/24       #3: Pass thru door alignment ...
Robert
Matt-sorry, local term I guess lol. The left door closes as it should, on plane. But the right side door closes and the bottom goes past the other door, like it was closing into the cabinet. Sorry, I don't have pics.
6/9/24       #4: Pass thru door alignment ...
Matt Calnen
Not sure what your set up is, but you could do a mullion/astragal strip on the back side of one of the doors to help with the sitch. You should be able to see if it would work by simply seeing if you can push the “dive” out. Of the offending door from the back side. I have used magnets to help with alignment on bifold pocket doors. I assume you have a stop at the top for the doors to land on, would it be possible to have something at the bottom to stop them as well, possibly a ball catch as you mentioned? As I said, hard to offer suggestions without a picture. Good luck and hope this was helpful.
6/11/24       #5: Pass thru door alignment ...
Leo G
These might work for you.
Adjustable door stops.
    Lamello
