1435 SE Holzher edge bander
6/19/24
Dennis Member
I have a 1435 se Holzher edge bander. The guillotine will stay in the cut position and not retract. I have check the plunger that is clean and secure. The air pressure is correct. I have owned this machine since 1989 it has been a good unit until now.
6/20/24       #2: 1435 SE Holzher edge bander ...
Jim Herron
Just experienced this.
There is a pin that has a cotter pin through it that rides in a slot that guillotine slides on
The cotter pin had sheared and came out allowing the pin to partially back out, jamming the cylinder in the cut position and not allowing it to return to its ready to fire position.
Check that, but unplug the air first, to keep it from slamming back when the pin is pushed back in.
If necessary post a number and I'll send a photo
Richard at Bayside Industrial diagnosed mine over the phone. Highly recommended HH technician. He knows the machine and has parts
Mine is a 1435 SE also
6/20/24       #3: 1435 SE Holzher edge bander ...
Jim Herron
Or send me an email by clicking on my name with a phone number and I can text a photo of the pin
6/23/24       #4: 1435 SE Holzher edge bander ...
You might need to sharpen the guillotine?
