Holzer 1402 hf edgebander
7/10/24
John B Member
Website: http://woodmanseewoodwrights.com
Hello,
I bought a used Holzher genesis 1402 hf machine a while back, had a service tech from reliable machinery do a once over on it checking motors, belt, cutters, etc, and gave me some basic instructions on it. It included a manual but it is not for the exact same model so not much help.
I didn't use it much since he was here, and now, just starting a new project. Banding 3/4" maple ply, using 7/8" wood banding. Went well for first part of run but now I am getting some up and down variations on the banding with it dropping too low occasionally. I have tried adjusting what looks obvious to no avail, wondering if I'm missing the proper adjustment or is this common for 7/8" banding on 3/4" material? Longtime cabinetmaker using face frames so no real edge banding background. Any other 1402hf owners out there that could copy a manual? I've searched the internet with no luck.
7/13/24       #2: Holzer 1402 hf edgebander ...
bob
first check that where edgeband exits guillotine
tape should have maybe 1/32" up/down movement
next check where tape enters there is a rod to hold tape down, adjust so that tape is upright w/almost no slack
also check that board thickness is down tight
good luck
    Lamello
