Panel Genie
Hinge
9/7/24
Chris
Is there a euro hinge available that will work for this application and not bind? Inset door 1” thick
9/8/24       #2: Hinge ...
Chris,
This may be possible, but I could answer with certainty if I knew the construction details behind the door.
Is there a frame or some other blocking behind the door to mount the hinge? Or.... is the door simply flush, in line with that side portion?
What is the radius of the door curve?
Is it possible that you have a drawing that shows the construction details?
Here is a drawing with a 1-1/8" thick door that may be your solution depending on your construction details.
If you have a drawing, please email it to me at:
dennis@saliceamerica.com
Regards,
Dennis
View higher quality, full size image (955 X 1443)
    Lamello
    • CabinetCRUNCHER
    • GreCon
    • Original Saw Company
      Industrial Radial Arm Saws
    • Impact Search and Placement
