making balance panel
10/14/24
richard goodman
Website: http://lagunabamboo.com
I need to make 2 cabinet doors 20" x 85" i had walnut milled 9" wide x 1/4 " thick. My approach it to glue the walnut on both sides of a 1/2" substrate. Any feedback on what substrate to use, what adhesive, or what method you would suggest.
Thanks Richard Goodman
10/15/24       #2: making balance panel ...
I would use particlecore and polyurethane adhesive. I hope you have at least a vacuum bag for clamping. Preferably a veneer press.
I would not use any glue that will add moisture to the walnut. It would cause the hardwood to cup and make it difficult to glue.
I would think about edge gluing the 9" pieces before pressing to the substrate otherwise it would be difficult to keep them positioned properly. Check to see if the walnut is flat before gluing.
10/19/24       #3: making balance panel ...
If you glue hardwood to a basically inert manmade product, there's a great chance the walnut with crack when it shrinks this winter. 1/4" thick wood is not a veneer and will act like any other board unless it is quarter sawn.
10/19/24       #4: making balance panel ...
By the way, your pictures are oak, NOT walnut.
    • J&P Machines
    • CabMaster Software
    • Lignomat
