grooved/coved/beaded panels
10/22/24
Chris
Has anyone found a company that makes a panel that has grooves or coves etc?
We keep getting requests for this. I know there are shiplap type products that you can sue to a panel but what a hassle and also an unbalanced panel. I recently found this panel but its only available in Germany
https://www.vd-holzinform.de/en/products/
10/23/24       #2: grooved/coved/beaded panels ...
BH Davis  Member
If prefinished panels are not required then why not just have them produced on a CNC? Straightforward to do with the correct aggregate head and/or router bits alone.
10/25/24       #3: grooved/coved/beaded panels ...
John Costin
Art For Everyday
https://artforeveryday.com/product-category/panels-standard-products/
10/26/24       #4: grooved/coved/beaded panels ...
Chris
Thank you. Art for everyday panels are solid glue ups that are then cut on a CNC.
That would t make for a very stable door.
The hunt goes on.
I thought I posted my answer for my not wanting to make them. The main concern I have is I dont know how that would work. Gluing 1/8" - 1/4" solid wood to both sides of a panel in an attempt to balance the panel but then removing material from only one side of the panel (grooves or coves) and hoping the panel stays flat seems a doomed idea.
Seems like the wood would also crack cuz it can't move ...the list of problems go on. I wonder if there is a solve for this at all. Thanks for the input guys
