Shop Work FLow
11/4/24
J Member
We are a fairly new cabinet shop. We have 2 CNCs cutting parts. I have 4 guys currently in the shop. My question is what is the most efficient way to build? My current process is this (i know it isn't the best).
1. Cut Parts on cnc
2. Edge band parts needed
3. Everything goes to build tables where they separate parts into each cabinet, pocket hole sides to connect ff then build.
Should we be organizing parts as soon as they are cut, also when should we take the time to edge band and pocket hole sides?
11/4/24       #2: Shop Work FLow ...
Stuart
I would endeavor to pocket hole your case parts on the CNC. Even if it is a flip op, you'll save time on that over doing the manual operation.Otherwise it sounds very similar to the way our production shop does it. Some folks dope out the parts to each cabinet at the edgebander, but we don't have a labeler, so that is done at the bench where we keep white papers and shops for assembly clarification.
11/4/24       #3: Shop Work FLow ...
J Member
Thank you for response. In wasn't aware a cnc would pocket hole but defiantly going to check into it. Thank you
11/4/24       #4: Shop Work FLow ...
Cutting pockets on the router is a much faster way to go about it.
I organize parts as they come off the cnc. It's much easier in my opinion to sort them that way, versus having a pile of parts and trying to put them in order then.
I clump everything together for an individual cabinet together vertically on a cart minus stretchers, nailers, toe kicks, and adjustable shelves. I rarely cut backs on the cnc. Stretchers and nailers are clumped together, in order. Shelves have further machining after the cnc, and nosing that needs to be applied.
I'd like to hear more about how you're operating two routers.
