How do you store specs for your hardware, out in the shop?
12/5/24
Matt Member
Anyone here have a spiffy way of saving hardware specs for use out in your shop? At least, for hardware items that are common, commodity items that get used daily. Not the uncommon "once a year" hardware like unusual spice pullouts etc.
I don't necessarily mean the printed copies you get from companies like Grass, Salice, etc. Those often have so much overkill information that you spend way too much time looking up your application.
I'm looking for ways of being able to put together our own "cheat sheets" to use for training purposes.
12/5/24       #2: How do you store specs for your har ...
I actually write well used specs on the wall. That way they can't get lost.
12/7/24       #3: How do you store specs for your har ...
Kerry Fullington
Matt,
We are paperless so everyone in the shop has a tablet. ($79 each. It doesn't take much) All documents (cut lists, shop drawings, elevations) are loaded in a Microsoft One Note Notebook that the shop can access. You could create a notebook called Hardware Specs. Place your specs in that notebook and share access with the shop and they can look up specs from there. They can even view on their phones if they want.
12/9/24       #4: How do you store specs for your har ...
Matt Member
We are getting pretty close to being paperless, so I hear what you're saying.
We have some things up in the office we need to change to go completely there but it's in the works.
Thank you for that, it helps to see other companies going paperless.
