Edgebander glue color
12/18/24
Harold
Hi everyone, I have an ambition Brant Bander with premill a use natural glue pellets. We have it tuned to give us perfect edges without pu glue . We still have an issue with white, still see the glue line, has anyone solved this by using white glue or clear glue ? We have it tuned to the thinnest glue line possible and don’t know if white glue would show on colors or if clear would be good for white? Can’t afford a second glue pot . Anyone have experience with this issue?
Thx, Harold
12/23/24       #2: Edgebander glue color ...
Matt Member
We used a Brandt Ambition for about 7 years, it was a good machine until we outgrew it.
We used Dorus KS351 in clear and did quite a lot of white melamine. While you still saw the edgeband joint, I would not say it was an issue at all. We didn't experiment with white glue because we would be changing from one gluepot to another quite a lot since white was only about 1/3 of our offering. We just used clear on everything.
Our current bander has Airtek capabilities and this is the only way I'm aware of to make that glue joint basically disappear.
12/31/24       #3: Edgebander glue color ...
Bozzy Member
We band a lot of white and gray material and the white glue makes all the difference. Need to be 6" away to see the glue line. We purchased a second glue pot because we switch colors every day, sometimes multiple times per day.
Before we got the second glue pot, we would start loading the glue pot with white glue couple of hours before we needed it so the clear glue would be used up by the time we got to the white panels. This way we didn't have to the overnight switch.
