Old Blum hinge
8/5/16
mark
Does anyone know a source for the old-style Blum compact face frame hinges that have a reverse boring pattern? The model is 30.310-11.02. It hinges on the straight side of the door cup. Replacements that I've found look the same except that they hinge on the semi-circle side of the door cup, which require patching the old dowel holes. Any ideas? Shy of new doors...
8/6/16       #2: Old Blum hinge ...
Wow! That is an oldie. Did you try contacting Blum directly. They would probably have some or know which of their distributors or kitchen manufacturers had ordered this in the past.
3/16/25       #3: Old Blum hinge ...
sherwin dubren
I purchased a replacement for a 30.310-11.02 Blum Cabinet Hinge from Amazon. They claimed it was a simple swap using the existing face plates on the cabinet. However, when the door is positioned properly, it will not close completely with a gap of about 1 or 2 inches. Amazon says I should be able to utilize the existing face plates that the hinge hooks onto. The brand of the hinge is Aituzero, but I cannot find any support from them. Blum has discontinued this hinge, so they probably cannot help me. I tried adjusting the positions of the plates, but that did not help. Any other ideas?
    • J&P Machines
    • CabMaster Software
    • Lignomat
