Edgebander chipping veneer
4/9/25
Michael Hermon Member
My edgebander has started chipping the veneer on the bottom piece happening from the front trimmer. Even when I adjust the angle so the blade is cutting the edging and is adjusted so that it doesn't contact the plywood, the veneer still gets chipped out. If I turn off the trimmers, no problem.
Has anyone else ever come across this? Its a Masterwood MWB43, Made by Technoma
View higher quality, full size image (1440 X 1920)
4/14/25       #3: Edgebander chipping veneer ...
Bozzy Member
Cutting on cnc?
4/14/25       #4: Edgebander chipping veneer ...
Yes, parts cut on CNC. Been using this edgebander for many years without this problem showing up.
4/16/25       #5: Edgebander chipping veneer ...
Bozzy Member
We've had a similar issue recently where the onion skin cut offset 0.2mm from the first pass and the end trim would snag that and chip it. We adjusted the CNC and the problem went away.
    • Impact Search and Placement
    • Lockdowel, Inc.
    • Doucet Machineries Inc.
