Glue Overflow on my Edge Bander
5/21/25
Elias Member
Website: http://homeimprovement-lb.com
I have a Biesse TM15 Hybrid Glue pot with premelter.
my premelter is causing glue to overflow from my glue pot, the green light is on (which indicates that the pot is full) but the system is still activating the premelter which is causing the overflow.
I cleaned my premelter as well as the glue pot sensor but the problem is still there, i also calibrated the sensor and that also did not solve the problem.
it looks like the problem is downstream from the sensor.
Any Ideas ? did anyone had that issue before ?
5/31/25       #3: Glue Overflow on my Edge Bander ...
Bozzy
We have the same issue with the premelter on our Morbidelli bander. Happened once while the scm tech was there and he couldn't explain what was going on. Please post here if you come across a solution.
6/3/25       #4: Glue Overflow on my Edge Bander ...
Elias Member
We ended up changing the level controller (Senotec CLS 45)
