Sawstop bearings running hot?
6/5/25
FM
I have a six month old Sawstop and the bearings and the shaft seem to run hot. My last Sawstop and previous saws before that I don’t remember them feeling this hot. I finally put my IR thermostat gun on them today and it came back 156F? Anyone bored and willing to check what yours runs at after 30 minutes or so? Thank you
6/8/25       #2: Sawstop bearings running hot? ...
That is not normal. Check the belt tension first. You should be able to deflect the belt by a 1/2" or so with finger pressure.
6/8/25       #3: Sawstop bearings running hot? ...
I agree with Tom. Check belt tension first
6/8/25       #4: Sawstop bearings running hot? ...
FM
Thanks for the response. Belt is just right. What does yours measure out tempature wise? Arbor or bearing assembly. I don’t have another professional table saw within a 100 miles of me and I don’t feel like getting the old one from the barn and hooking it up and running it to see.
6/8/25       #5: Sawstop bearings running hot? ...
No idea of the actual temperature but they have never been hot to the touch. My guess is about 10° above ambient after a full day of ripping.
Make a warranty call. If you ignore it - it will only get worse.
6/9/25       #6: Sawstop bearings running hot? ...
Always best to check with a bearing manufacturer.
Bearing rings and balls
SKF deep groove ball bearings are heat stabilized up to at least 120 °C (250 °F).
https://www.skf.com/group/products/rolling-bearings/ball-bearings/deep-groove-ball-bearings/temperature-limits
6/10/25       #7: Sawstop bearings running hot? ...
While it may not pose a problem for the bearings to run hot, in this case there is something causing the heat - improper preload, mis-aligned bearings, a bad bearing etc. Best case is that the bearings were overloaded with grease but I suspect these are permenantly lubed bearings.
6/10/25       #8: Sawstop bearings running hot? ...
FM
Yeah…the saw is functioning fine. There is just extra heat from somewhere. They spin fine by hand with no noise or roughness. Sawstop went ahead and is sending me a new bearing assembly. My last sawstop lasted me over ten years before the bearings went bad so it’s disappointing to have something go wrong right out of the gate. But they did step up and send the part out at no charge. I have bought 4 pieces of machinery since COVID. All 4 have had issues. From downright “blow up” when plugged in to parts in the bottom of the pallet that requires us to repair it out of the gate and now this. Seems to be the case with autos, appliances…
I don’t have the time to fix this immediately so I’ll have to run it like this for awhile longer unfortunately.
Thank you for your input and help
6/25/25       #9: Sawstop bearings running hot? ...
Bearings can be odd.
I once purchased a large American made gang ripsaw with a 50 hp direct drive motor. One very serious arbor/armature riding in two bearings. A beautiful machine.
Upon first startup, there was an odd sound. Shut it off and the arbor stopped right away. The bearings were both seized. Called the manufacturer, and they sent replacements overnight. They were surprisingly easy to replace. Started it up, and it ran fine. As it did for years.
It was explained that the high precision bearings had a high failure rate at initial service. Normal. What was unusual in our case was both bearings were bad from the start.
I used an infrared thermometer to measure bearing heat with readings directly from the bearing or housing. Great for diagnosis and isolation.
6/28/25       #10: Sawstop bearings running hot? ...
Dan/drb
I’ve replaced the bearings in both my 5hp industrial saws. They started getting awfully loud, it’s a simple job if you’re good with your hands . The bearings are readily available from any bearing supplier
11/29/25       #11: Sawstop bearings running hot? ...
SaraWil1515 Member
Most table saw arbor bearings I’ve checked (including on my SawStop) usually sit around 110–130°F after steady use. I’d keep an eye on it — excessive heat can mean the bearings are too tight, under-lubricated, or starting to fail. Since it’s only six months old, I’d contact SawStop support and have them document it.
    • Impact Search and Placement
    • Western Dovetail
      Custom Made Dovetail Drawers
    • GreCon
    • Machinery Associates
