Hawa Connecta vs Blum Revego vs ???
2/11/25
Chris
Architects keep wanting us to do pocketing doors. We stopped offering Accuride or KV due to the doors marring on the front as they are guided into the pocket with a plastic guide/wheel. The Concepta and the Revenge look great but OMG it looks nightmarish to install. Has anyone installed these? PITA? Is there something easy AND good???
Thanks fellas
2/12/25       #2: Hawa Connecta vs Blum Revego vs ??? ...
Chris.
You may want to take a look at the Salice Excedra pocket door system. It has become quite popular, and Salice will work with you every step of the way.
Salice assembles the hardware for you, customized to exactly what you need.
If you would like the full details, please let me know.
Regards
Dennis Bean
Salice America
Technical Support
View higher quality, full size image (634 X 858)
Salice Excedra Pocket Door
2/12/25       #3: Hawa Connecta vs Blum Revego vs ??? ...
Tony
Chris-same situation here. I've turned down a few jobs for that very reason. Can't keep the doors from scratching. I need an alternative as well.
2/13/25       #4: Hawa Connecta vs Blum Revego vs ??? ...
Sergio Member
Hi Chris,
I completely understand your frustration with pocket doors; I had a similar experience when I installed one myself. The system mentioned is indeed a great option, but if you're looking for easier installation, you might want to check out some other systems as well.
For a comprehensive guide, I recommend watching this step-by-step video on installing a sliding pocket door system: https://www.youtube.com/watch?v=fzVF1IDerko. It made some of the tricky aspects much easier to handle.
Exploring different manufacturers can lead you to find the right fit, and many offer great support for installation. Best of luck with your projects!
2/21/25       #5: Hawa Connecta vs Blum Revego vs ??? ...
Scott Markwood
Website: http://www.hafele.com
I'm one of the trainers at Hafele America Co and last summer we did several workshops for our sales reps where we installed pretty much every pivot/pocket system on the market; started with antient wood followers and rack and pinion systems through all of the current systems including the Blum Revego, the Accuride 1532, the Salice Exedra, several Hafele Slido F-Park products and the Hawa Concepta II and the new Concepta III.
While all of them have their advantages and disadvantages, in my 35 years of installation experience I have never installed an easier system than the Concepta III. I suggest you chat with your Hafele rep and give one of the new systems a try.
View higher quality, full size image (1512 X 1512)
View higher quality, full size image (2771 X 1558)
View higher quality, full size image (877 X 1558)
2/21/25       #6: Hawa Connecta vs Blum Revego vs ??? ...
Chris
Website: http://tomasi.us
Thank you so much! I made a sporadic decision to come out to KBIS next week to see the Exedra, Concepta 3, and Revago. I briefly spoke with Beck Newell yesterday, and she sent some info as well. Thank you again.
3/3/25       #7: Hawa Connecta vs Blum Revego vs ??? ...
Dan/drb
We use the Revego , it took one time to figure it out but now that we do , it’s the best one we’ve used and will continue to. But it’s not cheap be ready to spend money and time . It’s worth it . If you have any specific questions I’d be happy to answer them . The reps are great but they don’t know everything.
6/13/25       #8: Hawa Connecta vs Blum Revego vs ??? ...
Scott Markwood
BTW, if your design allows for an inset door, the Accuride 1532 is by far the quickest and easiest to install, in part because it installs inside the cabinet. If you’re installers are familiar with the installation traditional furniture pivot/pocket door system, such as the Accuride 1332/1432 or the Häfele XL pocket door system (now called the Häfele Slido F-Park 71 16A), they will find the 1532 to be super intuitive and outrageously quick to install in comparison to all the others in a similar weight and size class. In fact, that system is capable of handling an almost 10' tall door! We did a workshop with a OEM cabinet manufacturer in Pennsylvania comparing a variety of the current pivot/pocketing door systems on the market, and their final conclusion was that the Accuride1532 was the right system for them. Because of their prior experience with traditional cabinet pivot/pocket systems that their installers took to it like ducts to water!
View higher quality, full size image (1152 X 1613)
    • J&P Machines
    • CabMaster Software
    • Lignomat
