Miele madness
7/22/25
tom ruth  Member
Designing a kitchen with a Miele french door fridge 36". Sounds like you can't really get the stainless fridge doors to be flush with the cabinet doors? I'm ok with that, but are there any good drawings that help you figure out how to get the adjacent cabinetry to line up with the fridge doors? It would also help to know the total height of the doors together. Installation instructions only get you so far. Or what am I missing?
7/24/25       #2: Miele madness ...
Mark Bruins
Website: http://hhcabinetry.com
I had a similar challenge with their dishwasher. The drawings included in install documents showed a lot but not what I needed. Scrolled to the bottom of Miele appliance page and found an additional link to Documents Library. Maybe you can find what you need here.
7/24/25       #3: Miele madness ...
tom ruth  Member
Thanks Mark, I did notice that documents library, will check there again. I think there were some CAD drawings at least. I'm thinking now it might be better to go with the panel ready model if it's possible to buy stainless doors from Miele. I had a good talk with my appliance sales person and he said a large part of his time is dealing with homeowners and cabinetmakers in trying to figure out installation solutions. It looks like with the panel ready model, you don't want to build a box around it, you simply install it between adjacent cabinetry as the opening should be 36" wide with the fridge doors being 25 3/4" wide. This is a different installation method than lets say a Liebherr panel ready. I did a Liebherr and it was pretty awful.
7/24/25       #4: Miele madness ...
Mark Bruins
Tom, I remember when Sub Zero used to drive me nuts. Now they're the easiest ones out there. If someone mentions Fisher Pakel....run!
7/25/25       #5: Miele madness ...
Jim Kolar
Miele specs are tough. Never a complete divinified answer that we need. I have shifted all the appliance liability onto the customer and builder. I won't start production of any job unless final specs are provided and identified on the spec sheets. When I submit bids, this is noted. I do have a charge for each appliance in the design part of estimating for my time to verify what they have provided.
7/27/25       #6: Miele madness ...
I've called manufacturers to get clarity.
Another option that I used to do a lot was refuse to build an appliance panel until the appliance was sitting in the hole.
Instructions are better than they were 10 years ago, but if you misread something or what they give you is actually false, then you're stuck remaking the panels after the fact anyways. So it's an easy sell to the contractor. "Listen, you can get them now, but they'll be wrong. Or you can wait a few days and get them right and I'll just charge you for one"
7/30/25       #7: Miele madness ...
Kevin Jenness
I won't do appliance panels without putting my hands on the unit. That goes double for Fisher Price.
