Antrader Hinge Install Detail
8/13/25
Lawrence
Hi. Fyi, I'm not a professional. I'm trying to install an Antrader Brass Butler Tray Hinge to a cabinet to add a drop-down leaf. I've got the oval mortise for the hinge body. But the bottom side of the hinge needs additional mortising to fit flat (see image attached). Which side does the additional mortise need to go on? The cabinet or the drop leaf? Thanks.
View higher quality, full size image (991 X 547)
8/13/25       #2: Antrader Hinge Install Detail ...
Lawrence
Well. Impatient like an apprentice; I put the secondary mortise on the drop leaf. After making a mock-up of the hinges with some scrap wood, it appears that either way you orient the hinges, the same amount of hinge appears when the drop leaf is in the up position. Then I flipped a coin. Problem solved. Thank you. It helped that I was able to talk it out on this forum.
    • J&P Machines
    • CabMaster Software
    • Lignomat
