Metal faced MDF
8/4/25
Chris
Looking for some Metal faced MDF for a liner in an outdoor kitchen range hood cabinet. Not sure if this is the best ideal or not. The builder of the house wants me to build a swoop sided range hood and install this in it and he would get the blower to go inside . Hood will be 24” deep x 36” wide.
8/14/25       #2: Metal faced MDF ...
Craig Caughlan
When I've wanted more protection than Melamine can offer, I've gone to my sheet aluminum supplier for 22-24 ga. and then using a good adhesive or contact cement. It certainly is a lot less expensive than buying a metal-clad HPL
8/14/25       #3: Metal faced MDF ...
Chris
Craig
How does that look? Does the aluminum and the SS. range hood match up enough in color that it’s not noticeable?
8/19/25       #4: Metal faced MDF ...
Craig Caughlan
There is a difference. When you peel the protective film off the aluminum, it is more brilliant. But you can take 3M abrasive pads to knock it back. It may be that your sheetmetal supplier sells SS. There are names for various finishes: brushed, satin, etc. Bottomline: it's possible to match, or closely match, what you have without buying an entire sheet of HPL clad in SS.
