Inset doors for pullouts?
10/20/25
Doug Member
I'm going over plans for a deVol inspired kitchen cabinet job and I'm seeing a lot of pullouts with inset door front panels. Is this an issue? I imagine it's just a matter of time before it gets wonky and start rubbing/hitting when closed. Are inset pullout a thing shops do successfully or is this asking for problems down the road?
Also, there are two cabinets with very tall doors which are supposed to be inset with butt hinges. This also seems like asking for trouble given the likelihood of wood movement and the trouble of adjusting the reveal. Should I insist on concealed hinges?
Thanks for your thoughts
10/21/25       #2: Inset doors for pullouts? ...
The best hardware solution I found for pull-outs that maintain proper door gaps is to use metal drawer boxes (Hettich in my case) that have three way adjustment. Multiple drawers/shelves can be mounted to the door front others can pull out once the pull-out is opened. In my experience the drawer fronts keep their settings well even for a full length front.
10/28/25       #3: Inset doors for pullouts? ...
NJ Furniture Mart  Member
Website: https://www.njfurnituremart.com/
Inset pullouts can work beautifully if built with precision and high-quality hardware, but they require tight tolerances. Over time, slight shifts or wood movement may cause rubbing or misalignment. Skilled shops can manage this, though it’s more maintenance-prone. For tall inset doors, concealed adjustable hinges are generally a better choice, they allow easier fine-tuning and compensate for seasonal expansion. If you’re concerned about long-term performance, insisting on concealed hinges is a smart, practical decision without compromising on aesthetics.
