Semi gloss troubleshooting
3/29/26
Cindy Member
I am having trouble with semi gloss bubbling. Im using Ilva 1k waterbased paint. Spraying with the graco finnix hvlp cup gun. With a 15 tip. Ive tried low air and it gives a dull dry finish. And if I turn up the air I get bubbles. I've tried adding a 3% retarder. But still having the same issue. I've tried a tack coat, then Spraying another coat. But that leaves a pixelated look. Any advice would be appreciated. Thank you
