Large murphy bookcase
7/8/26
Perry Vavra
I’ve built a few Murphy book cases in the past no problems. The one I’m about to start on will be 4’w x 8’ h. out swing. I haven’t had to build one this size so I have a lot of concerns. The hardware needs to be concealed so I plan to use rixom hinges and use 3/4” ply on the back which I will cut dados into the sides so the back will be let into the dados glued and screwed. I would appreciate any thoughts and or advice on weather my approach will work. Also is there a certain rixom hinge that would handle the job?
Thanks.
