Kerfed Walnut slab doors
8/18/26
Thomas Member
Good Morning Fellas
I need to make kerfed walnut doors. my thought was to lay out 1/16" walnut on cross grain both sides of a 1/2" core, then another layer of 1/16" walnut on the long axis. Cut the size out I need - edge band and then kerf as dictated by the layout.
I am concerned about warping and movement... upper doors will be just shy of 58" x 21".
Thoughts or suggestions?
8/21/26       #3: Kerfed Walnut slab doors ...
How deep do you want your kerf? I would test applying 1/16" veneer to one face of 11/16" walnut particle core with urethane glue to add no moisture. Cut, band then kerf soon after.
My theory is that if you are cutting through the 1/16" veneer effectively neutralizes its effect on warping the panel.
Definitely do tests before commiting to any method. I have not tried this before.
    Lamello
