Kerf360: Parametric Cabinet For Autodesk Fusion
10/6/26
Yazan Shawakha Member
Website: http://kerf360.com
Hi everyone,
I'm the developer of **Kerf**, a third-party add-in for Autodesk Fusion, and I'd really appreciate feedback from people who actually design and build cabinets.
The whole workflow stays inside Fusion:
**How it works**
* Draw one rectangle per cabinet on a floor-plan sketch. Kerf generates a parametric cabinet for each rectangle, facing the room.
* Text inside a rectangle controls that specific cabinet. For example:
`2565mm G1700 DS OAK TK100`
creates a 2565 mm pantry with a gola line at 1700 mm, Shaker doors, oak, and a 100 mm toe kick.
* Construction lines split cabinets into compartments.
* L-shaped profiles create corner units.
**What it produces**
* Real Fusion bodies with Blum / System 32 drilling
* Cut lists in mm or fractional inches
* CNC nesting or table-saw breakdowns
* QR-coded part labels and assembly sheets
* Quote PDF and costing CSV
* Fusion Manufacture setups per sheet and G-code per tool
* Layered DXF for other CAM software
Here are a couple of videos:
🎥 **Sketch → Kitchen:** https://youtu.be/MoC9g82tIKo
🎥 **Tutorials & sketch-code shorts:** https://www.youtube.com/@kerf360
🌐 **Website:** https://kerf360.com
**Windows only at the moment.**
If you model or manufacture cabinets in Fusion, I'd genuinely love for you to try it and tell me where the workflow falls short.
I'm especially interested in feedback on:
* cabinet configuration
* construction methods
* CNC workflows
* cut lists / nesting
* hardware drilling
* what you'd want automated that isn't currently automated
It's free to try, and I'm much more interested in *how you'd use it* than just hearing whether you like the idea.
Thanks!
https://kerf360.com
    Lamello
