45 degree corner toe kick
11/11/26
Barry Golash
I'm drawing a 45° corner base cabinet and have run into a geometry issue with the toe kick.
The adjoining base cabinets use a standard 3" recessed toe kick. When I carry those recess lines into the corner cabinet, the resulting setback on the 45° toe kick face works out to roughly 2.12" rather than 3".
It appears I can't have both:
• A true 3" recess measured perpendicular to the 45° face, and • A toe\-kick line that visually aligns with the adjoining cabinets.
For those building diagonal corner cabinets, which approach do you use?
Do you prioritize maintaining the visual toe\-kick line around the corner, or do you keep a true 3" setback off the angled face and let the alignment fall where it may?
I've attached a CAD detail showing my current layout and would appreciate seeing how others handle this.
View higher quality, full size image (1229 X 822)
    Lamello
    • CabinetCRUNCHER
    • GreCon
    • Original Saw Company
      Industrial Radial Arm Saws
    • Impact Search and Placement
