Computer Aided Design
Subject: Re: Inventor vs. Solidworks
4/10/14
Chad
We are looking at upgrading our 2009 version of Inventor to Inventor 2014. We have not used the program much since we bought it. Due to the learning curve we outsourced our shop drawings.
I have decided to bring the shop drawings to the office so we have more control. We have hired a new estimator with a drafting background in Solidworks.
The new guy of course wants me to purchase a new seat of Solidworks instead of upgrading Inventor - which the pricing is pretty comparable.
I thought Solidworks was used more in metal working than woodworking.
We are an Architectural Millwork shop that builds windows and doors.
- Is Inventor or Solidworks a better program for millwork and why?
- Any other thoughts of which program (Inventor or Solidworks) I should use for shop drawings?
My intention is to use the program to get a approval sign-off from customers, create a cut list for the shop, create changes on the fly when we need to and have it documented.
4/13/14       #2: Inventor vs. Solidworks ...
Hans Mueller
Website: http://www.haustueren-mueller.de
You are right - Solidworks is a mechanical CAD, same as Inventor. For that we use Solidworks with Pascam Woodworks, which is fully integrated in SWX. We build our individual doors with it since years and itīs working fine for us. SWX without Woodworks didnīt work.
From good old Germany
Hans
4/13/14       #3: Inventor vs. Solidworks ...
Richard
HI Chad.
I only have experiencece with Solidworks but from my understanding Inventor and Solidworks are very comparable in terms of features and functionality. As Hans mentioned Solidworks is a mechanical CAD package and a lot of it's features are more than what's required for designing millwork. However you can easily generate custom millwork in Solidworks as well as build libraries of more standard products.
The problem I always had with Solidworks was how to efficiently get the information out of Solidworks and into my CAM system. Pathfinder 3D is a plugin for Solidworks that extracts all your components as layered DXF files that can be imported into your CAM package. For me it is what really makes Solidworks a viable option for millwork.
If you have any more questions about Pathfinder please contact me.
Regards
Richard
4/13/14       #4: Inventor vs. Solidworks ...
Chad
Thanks for both of your responses. The information regarding the add-ons is helpful.
I am concerned a little about your comments about transferring files to your CAM system. We have a Biesse Rover that we use for machining doors parts as well as other parts. Currenty we draw all the parts using BiesseWorks and then run them. We would like to start using whatever drawing program we choose to send information to the machine.
From what I am reading - I need another program to run millwork items in Solidworks because it does not have a CAM package?
Can you explain further why Solid works did not work without PasCam Woodworking? Is PasCam Woodworking available in the US? Does it have good support?
I would like to hear from someone that uses Inventor in a millwork shop as well as any other comments from either Solidworks or Inventor.
4/13/14       #5: Inventor vs. Solidworks ...
Richard
Both Solidworks and Inventor are CAD programs and so either will require additional software in order to generate code for your Biesse.
Pathfinder is a plugin for Solidworks that automates the extraction of DXF files. The DXF files use different layers to indicate what tools should be used. These files can be configured so that your Biesse will automatically generate CNC files when they are imported.
Please take a look at the videos on the website as they do illustrate the process. Let me know if you have other questions.
Richard
Pathfinder
4/16/14       #6: Inventor vs. Solidworks ...
Kenny Belfatto
Website: http://www.cim-tech.com
I know the purpose of Woodweb is to contribute generally useful information and exchange ideas, and to not pitch products, but - Router-CIM works directly from Inventor OR Solidworks models and assemblies and it does full six sided feature recognition and tool path programming including aggregate tooling needed for window, doors, and millwork.
We work closely with Widom associates who offers woodworking tools for Inventor to boost your productivity.
Both Inventor and Solidworks are very good programs and have almost identical features. One advantage I see with Inventor is that you can purchase the design suite that includes a full copy of AutoCAD with it. I never heard anyone say they were not happy having a copy of AutoCAD.
4/20/14       #7: Inventor vs. Solidworks ...
Rufus Cooke
Website: http://shorelineparametrics.com
Chad,
I started using SolidWorks in 2001 primarily for the custom staircases that we were building (elliptical, radial, etc), but also found it useful for many other custom millwork applications. To accurately generate a lot of the geometry requires working the parts in the flat and then wrapping them into the required shapes. Naturally, this also enables us to "unfold" the faces for the shop floor's benefit. To do so requires the functions from its "sheet metal" palette of tools. These tools have been incredibly powerful and what (at one time) separated it from Inventor. At this point, I'm sure that Inventor has similar tools, though I have to say that SW robustness and consistency reflects their product's development. I think that by NOT producing a wide array of products so that there is "something for everyone", SW and its users have actually benefited.
4/20/14       #8: Inventor vs. Solidworks ...
One thing to consider is that for cabinets CV or MV are not going to be beat because of global parametrics. For the custom stuff 3d is not going be beat because of flexibility and to detail complex shapes.
But don't get the idea that a modeler is going to do what CV or MV does.
4/20/14       #9: Inventor vs. Solidworks ...
Rufus Cooke  Member
Website: http://www.shorelineparametrics.com
I couldn't agree more with Pat. I'm finding that the architects love the 3D because it makes their presentation easier. The problem is by the time a 3D model in SW or Inventor is completed, most of the engineering for the entire assembly is completed. Too much data gets thrown away at this early stage. What's needed at the concept stage is something fast and not necessarily accurate just for concept. So if the parts are mostly rectilinear, then CV or MV would be m choice too.
4/20/14       #10: Inventor vs. Solidworks ...
Stevew
Website: http://www.widom-assoc.com
Before you make the move , many woodworking companies are utilizing Inventor for not only design but design to CAM
Many have switched from other solid modelers including Solidworks to Inventor .
If you are laready utilizing 2d , all of your 2d data is bidirectional
Parts list , bill of material , edgebanding , joinery is available .
In fact it comes with a free 2 1/2 axis Cam program
Check out several of the videos at www.youtube.com/widomtech.
Inventor for the wood trades is easy to learn and quick to be productive
Also the least expensive
Woodworking Videos
4/20/14       #11: Inventor vs. Solidworks ...
Rufus Cooke  Member
I wish that the salespeople would stay out of these discussions.
4/20/14       #12: Inventor vs. Solidworks ...
Stevew
Website: http://youtube.com/widomtech
Before you make a descision take a look at what is working for the wood industry with Inventor .....
All size millwork , furnture and cainet companues see dramatic benifit
also the least expensive , easiest to learn and you can reuse your data from almost all cad products
4/21/14       #13: Inventor vs. Solidworks ...
Chad
I appreciate all your feedback in this thread.
Being a window & door manufacturer always makes me feel like an outsider in these forums - the conversation seems to always go back to making cabinets.
Any thoughts or experience out there of drawing full window and door units using either program?
Is it difficult to build a fully parametric window in Solidworks or Inventor? is it worth it - if it is custom or a one-off?
I have heard both of the programs have configurators but do not know how difficult it is to develop a configurator.
4/21/14       #14: Inventor vs. Solidworks ...
Rufus Cooke  Member
Chad,
generating a library with multiple configurations is no problem (or so the salespeople will have you believe) and in fact, it's not that difficult. However as we all know; the 'devil's in the details'. So while changing dimensions for components is easy, let's say you want to add a lock rail to a french door. Cosmetically, it may be easy, but there's still the joinery to consider (dowels, mortises, tenons, etc) This is where the automated parametric 3D modeling with multiple configurations gets tricky (and I've been using it since 2001). I know it's done and done ALOT in Europe with window, door, conservatory and stair fabricators. It sounds like they tend to favor SW, though I think it's more of a regional thing (we seem to be more Autodesk orientated here in the states). Anyway, to it set up automated libraries properly is a major investment of time, so take your time, visit with some expert users who know the business, tinker with the output to develop a realistic understanding of the software's limitations and make sure that whichever product you use will pay for itself over time.
10/24/19       #15: Inventor vs. Solidworks ...
Hiral Patel  Member
Website: http://www.hitechcaddservices.com
Inventor and SOLIDWORKS are two of the leading CAD modeling platforms utilized in most of the industries today and so, comparing these two is like comparing apples vs. apple.
Both are equally capable to help design engineers to model complex geometries with ease and have their modules or features integrated to extend the design for other departments.
However, I feel that there are certain important features can certainly differentiate these two leading CAD modeling platforms. You can find some of them here:
Comparison: Inventor vs. SolidWorks
    • Mastercam - CNC Software
      CAD/CAM Software for Milling and Turning, 3D Design and Drafting, Surface and Solid Modeling
    • ECabinet Systems
    • Mozaik Software, Inc.
      Software Tools and Services Designed to Assist With Design and Detailing Needs
    • EnRoute Software
      CAD CAM Software by SAi Featuring 2D/3D Design and Toolpath Functions, Nesting, Rapid Texture and More, with Low-Cost Monthly Subscriptions Available
    • 2020 Manufacturing Solutions
      Manufacturing Software Solutions Including an Offering Designed For Cabinetmakers, In Addition to Furniture, Architectural Millwork and Other Wood Product Manufacturers We Support
    • Cabinet Pro
