Computer Aided Design
Subject: Re: quick drawer front alignment
11/3/14
Brian Clancy
Hi
I have a small cabinet shop doing residential and commercial cabinets. I currently use Cabinet Parts Pro and VCarve Pro and am wondering if there are any other users out there that have a method, using their CNC, to create drilled holes in the backs of drawer fronts for easy attachment and perfect alignment . It would be like buying an IKEA drawer base where everything is predrilled and fits together perfectly. I don't think I can do this in CPP, but correct me if I am wrong. Or if anyone is using another program or method, I am very interested to hear. It seems like this is a bottleneck when I get to this part of the cabinet assembly. Any advice would be appreciated.
thanks
Brian
11/3/14       #2: quick drawer front alignment ...
Frank D. Jimenez  Member
Website: http://www.cabinetpro.com
Hi Brian,
Cabinet Pro CNC allows the user to machine any drawer parts precisely and automatically, including holes in the drawer front, notches and holes in the rear of the drawer box, etc. Machining can be global or based upon the drawer guide being used.
11/4/14       #3: quick drawer front alignment ...
james mcgrew Member
Website: http://mcgrewwoodwork.com
Ryan can write a script to do this in CPP same as he does the preconstruction drilling. We do this for our sides when we use 8mm confirmats, it will do drawer and hinge holes. I love CPP and still use it extensively, it may however be finally time for you to go thru a learning curve and step up to far more powerful and $$$$$ software CV, CW, CP, KCD and CPP will all do this, you may need to learn it as part of it no matter which you choose.
11/13/14       #4: quick drawer front alignment ...
ozan
it takes about two three years to learn technology cad , cam g code, its not simple. if you want to pay them to do it for you, you still need to learn how to write machine codes.
11/17/14       #5: quick drawer front alignment ...
derrek
Website: http://closetdr.com
I use cabinet vision. We drill the boxes for the handles on the cnc. We also have an intellijoint that drills holes for the attachment screws. When we do slab drawer fronts without handles, the intellijoint drills 3 holes, the center hole is drilled 10 mm higher so the installer knows what side is up. Holes in box are 5mm, holes in fronts are 3 mm diameter and 2 mm deep.
