Computer Aided Design
Subject: Re: Minimum depth for home theater cabinet?
7/29/16
robert
What is the minimum depth of a home theater cabinet you have drawn in your CAD system? Do you have a standard depth for home theaters?
7/30/16       #2: Minimum depth for home theater cabi ...
james mcgrew Member
I always engineer first based on the know Tangible numbers, get all equipment specs and look at depths and any other spec that matters, make sure to give room for cord clearances which may protrude after the install, on most equipment drawings these may not be allowed for. insure tv mount depths are accounted for as well.
while i do not do residential at all i used to make the home owner either give me the model number and invoice so i could obtain the pdf cur sheets or make them bring me the to be installed equipment,
once had a lady quietly figure she could switch a double oven for a single without telling me.
8/4/16       #3: Minimum depth for home theater cabi ...
The size is determined by the hardware installed and the sound desired. I think the smallest we have done is 4.5" in overall depth.
8/5/16       #4: Minimum depth for home theater cabi ...
Just checked, 4.5"w x 6.5"h x 4.5"d was the smallest. Biggest was a dual opposed firing 18" subwoofers 32"w" x 23.5h x 23.5d". Never heard it, but it was a beast.
