Computer Aided Design
Subject: Re: Cabinetpro
Cabinetpro
2/12/17
Randy Member
Does anyone have any experience with Cabinetpro? I would really like to know your impressions, experience, etc. Also advice. Thank you.
2/13/17       #2: Cabinetpro ...
Mike Wright Member
Randy: I've had Cabinet Pro since 2002, I started out with the standard edition and when I bought my CNC I upgraded. I think that at this point 15 years later I wouldn't know what to do without it. The CNC and Cabinet Pro combination are like having an experienced cut man that comes in on time, never takes a break, no cell phone use, no sick days, no vacations, etc. You get the picture. My advise is to not expect to be able to create flawless runs without taking the time to learn the software. It took me quite some time to be totally comfortable with it. After 6-8 months I was pretty satisfied with my results but I'm still learning, yes even today. BE PATIENT, EXPECT NOT SO PERFECT RESULTS FOR A WHILE. LEARN THE SOFTWARE INSIDE AND OUT. YOU WILL BE GLAD IN LONG RUN. Best of luck.
2/13/17       #3: Cabinetpro ...
Randy Member
That sounds great but how did you initially learn it? Do you use it for five piece doors? Can you wait a long time for support? Seems like a good enough program for now but I need some help. You have the program: If I need every flat panel door to have a 3/8 rabbet how do you program it?
2/14/17       #4: Cabinetpro ...
Mike Wright Member
That sounds great but how did you initially learn it? I learned the program by using the help videos and a lot of trial and error. Do you use it for five piece doors? 5 piece doors are typically made with a shaper so no. Can you wait a long time for support? "Can I wait a long time for support" I just call the tech support line and usually I get an answer. Seems like a good enough program for now but I need some help. You have the program: If I need every flat panel door to have a 3/8 rabbet how do you program it? I would use the cutting and drilling definitions section and create the rabbit that is needed. It will do that.
The process of learning any software of this depth is sometimes slow and frustrating but in the end it's worth the time. If you want to talk to me on the phone ask Frank for my number and I'll be glad to help you a little on a Saturday.
2/17/17       #5: Cabinetpro ...
yaakov katz
i only want to answer about yours coment about the 5 picess door
first its can create by cnc not only by shaper
also can use by second cnc ,no nesting
second even create by shaper you must export all diagram ,size ,groove ...many other details that need to buy the wood ,and to make the parts
so to say no need export from software ,to my opinion its not correct
attach is sample of one of the way that polyboard can handele the 5 parts doors
View higher quality, full size image (1366 X 768)
2/17/17       #6: Cabinetpro ...
Mike Wright Member
yaakov katz: The question about 5 piece doors was "do I make them on the cnc", my answer was no I do not. I did not say that they could not be made on a cnc.
2/19/17       #7: Cabinetpro ...
Randy Member
As Mr. Katz pointed out, the center panels of five piece doors are often made on a CNC in high production. That is exactly what I am trying to do. I need to be able to program a variety of panel designs so I'm not having to pay someone to stand in front of a shaper all day. At this point, the staff at Cabinetpro is helping me.
