Computer Aided Design
Subject: Re: Import dxf into Alphacam
4/18/18
Would anyone have an idea why dxf files created/modified by CorelDRAW can't be imported into Alphacam?
4/19/18       #2: Import dxf into Alphacam ...
I have had that happen on occasion. Can you get it to go into any other program that takes dxf's so you can rule out a corrupt file? CorelDRAW has not been good to me in the past.
4/19/18       #3: Import dxf into Alphacam ...
Works fine in every other program I have.
4/22/18       #4: Import dxf into Alphacam ...
keelhauled Member
Try saving as dwg.
Try saving as dxfR12
I know this is a roundabout way but
Download Inkscape (free programme as good as CD imho
Open your dxf in Inkscape and save as a dxf with a slightly different name for clarity.
In AlphaCam
Import Cad
Select dxf and import the Inkscape dxf
Let us know how you get on
Mick
4/23/18       #5: Import dxf into Alphacam ...
Dropout,
Then why not export a dxf, or any other sort of file from the programs that will accept the Corel dxf into Alphacam? Extra step, but should solve the problem, right?
4/23/18       #6: Import dxf into Alphacam ...
Will try the suggestions. Thanks.
Mike, so far once CorelDraw touches it, no matter what I do with it, AC doesn't like it.
4/23/18       #7: Import dxf into Alphacam ...
David Egnoski  Member
Website: http://www.richmondcabinet.com
Some Corel users recommend this.
http://www.coreldrawtools.com/professional/index.html
4/23/18       #8: Import dxf into Alphacam ...
My thought has always been Corel doesn't output to an industry standard dxf. It has always been the only software I have issues with. Alphacam imports a lot of different file types without issues, but Corel is the exception. Maybe because it is more of a drawing platform and less of a CAD program? I'd like to hear from someone that knows. I bought for myself personally an older version of Corel back when it was almost new, but threw it away after issues like these. Total waste of cash for me.
4/24/18       #9: Import dxf into Alphacam ...
Thanks for all the responses.
In some cases saving as R12 worked.
What is the difference between an ACSII and a binary file?
