Computer Aided Design
Subject: Re: V Carve Programmer Needed
7/3/18
Jon Member
I am in a really bad spot with a subcontractor. He is walking the dog on us programing parts at 200 IPM that can run at 600. All of the part libraries are in nests and tool associated. No individual drawings and he is in his last 25 days and I need someone to come in here and fix this mess because orders are a coming. We are in Sarasota Florida. If you know of any companies or individuals that can come in and take on this mess and get me back running RESPOND.
7/3/18       #2: V Carve Programmer Needed ...
Gary Balcom
Jon,
Sorry to hear of your situation. What is the actual machine? Why don't you just dig into the program file in a text editor, and figure out what you need to find and replace in the programs to change the speed? May be a faster fix you can do yourself, to get you through until you can find someone. Good Luck.
7/3/18       #3: V Carve Programmer Needed ...
Chevy
no fires or lawsuits this week,,i have time for some work,,post it here or email me,,,let me know what machine we are posting to and ill have to you
7/4/18       #4: V Carve Programmer Needed ...
james e mcgrew Member
Question are you Vcarving parts or using Vcarve Pro software, what are you actually doing ?
Something does not make sense, so help me understand, you are the cnc operator, someone is programming in vcp and sending you files ( machine code or vcp files) you are trying to run them and the feeds are to slow.
vcp toolpathing is a simple process. i can understand if you have never used it that it would take a short learning curve you do not have time for.
clarify some info as there are thousands of vcp end users out there. most all on the CAMheads forum use it
7/4/18       #5: V Carve Programmer Needed ...
Chevy
Or post a dxf or shop drawing,,,,I’ll redraw and apply a tool path to it,,,I just need the machine and tool info to post out good code.
