Computer Aided Design
Subject: Re: Microvellum Single Part Editor
8/21/19
Katie Member
I've been using Microvellum for a few months now but am just starting to get into building more custom products.
Currently I am trying to set up a piece for our router using single part editor. Because of the material we are using, we want to run multiple passes along the same line to get to our final depth. Every time I set this up I get an error. I'm sure I'm missing something since this is the first time I've tried to do this.
Currently I have it set up with multiple lines stacked on top of each other each with a different routing depth.
What should I do differently?
Thanks!
8/21/19       #2: Microvellum Single Part Editor ...
Nathan W Member
What kind of machine are you sending this too. I have had to run some realy deep routes and was unable to get microvellum to do this. However, using woodwop(homag), there is an option to mill in steps, enter your starting depth and how many steps you want and you are good to go. If this is a one off part id see if your machines software has something similar or issue a support ticket or future request in the microvellum forums.
8/22/19       #3: Microvellum Single Part Editor ...
Brian
Katie
You CAN stack the tool paths, but then you have to set the priorities. Why not build a 900 tool and assign it to remove a set amount until you reach the depth you set?
Try this and look at the generated code you should be able two see it step down.
8/27/19       #4: Microvellum Single Part Editor ...
Gary Balcom
You can do either. I prefer the 900 tool route unless I have a reason to deviate from it.
I have a product I make where I decided to use separate lines because I wanted to control the route priorities better. Post again if you have any issues, and one of us will help you out.
