Computer Aided Design
Subject: Re: Alphacam 2011.pgm files missing
2/10/20
Colby Member
So our cabinetry shop uses Autocad for 2d shop drawings and Alphacam 2011 and CV8 for nesting the parts.
Problem is that just recently when we attempt to output NC from Alphacam it does not create any .pgm files for our CNC.
Has anyone had problems with Alphacam not generating .pgm files out of the blue?
2/13/20       #2: Alphacam 2011.pgm files missing ...
Could be a couple of things. I am not sure if your post processor is VB or the old script type. Can you check if prior to output the default post got changed? You need to be using the same post. Next, is it making any code at all? Default file type is xx.anc rather than pgm. Last thing I can think of is Alternate file extension in the addins got unchecked. Good luck.
2/18/20       #4: Alphacam 2011.pgm files missing ...
DONALD WHATLEY  Member
If you are still having this problem give me a call 424-652-0563
    • The Millwork Studio
    • ECabinet Systems
    • CabMaster Software
