Computer Aided Design
Subject: Re: Transferring a Microvellum library
3/18/20
Ex-Pat Member
We are trying to telecommute as much as possible. One of my engineers has MV67 at home, does anyone know which files he would need to copy to update his library to ours?
Keep safe all.
3/19/20       #2: Transferring a Microvellum library ...
Nathan W Member
Im not sure about transferring files, but what about using a 3rd party software to remotely access his work station from home. Something like remote pc or team viewer? I use remote pc to work from home.
3/19/20       #3: Transferring a Microvellum library ...
Ex-Pat Member
That is what I do because I don't have $$$$ to drop on software. The lag is a huge issue accessing remotely, so I am hoping to avoid that for him if at all possible. It looks to me all he needs to bring is the Library and Subassembly folders.
3/20/20       #4: Transferring a Microvellum library ...
Nathan W Member
Not sure what version you are running. The newest update has a pretty slick database management wizard that's super easy to use. You would be able to export/import basically everything. I've only done projects but it looks like you can do libraries and sub assemblies. I'm assuming though if you import a library all your sub assemblies should come with it no?
3/23/20       #5: Transferring a Microvellum library ...
Brian
I guess my question would be if the library you are currently using will work with 6.7. If it does then you need the database, and the data directory. I have not tried it. I have tried TeamViewer from home, it works. there is just a tad bit of lag but nothing I can't deal with.
3/24/20       #6: Transferring a Microvellum library ...
Ex-Pat Member
We are running v67 here, that's what he has at home. He is a returning employee, what he has at home was our library from 2 years ago. I think if he copies the library and subassembly folders and replaces his old ones with them that ought to work. I'll let you know after we try it.
    • ECabinet Systems
    • INNERGY
    • Cabinet Pro
