Computer Aided Design
Subject: Re: Cabinet Vision Issues
6/3/20
Rob Polizzi Member
Website: http://www.danleewoodproducts.com
For some reason when I am in CV it will not let me do anything with my materials, for example I click on change material and my screen freezes and I have to press Esc. to and close that pop up to be able to at least do anything else. Has anyone had this issue and know how to fix it?
6/3/20       #2: Cabinet Vision Issues ...
Tyler
sometimes running CV Update will fix those weird glitchy things
6/4/20       #3: Cabinet Vision Issues ...
dave
Have you ever used dual monitors?
You have probably got a window opening up off-screen.....
Pres the Alt on your keyboard
Press the Spacebar on your keyboard
Press the M key on your keyboard
Press one of the Arrow keys on your keyboard
Use your Mouse to move the dialog to the desired position
If this doesn't work, there is a registry fix, I would need to know which version you are running....
12/19/23       #4: Cabinet Vision Issues ...
Devin
I have come across the same issue as described by Rob P. I am on CV version 2022 (2022.2.2228.477). I tried the Alt+SPACE+M+ARROW KEY and it did not work. Any other suggestions? Should try contacting CV support to see if there is a patch or more recent version?
12/19/23       #6: Cabinet Vision Issues ...
Dave
Try the registry fix...
View higher quality, full size image (1056 X 558)
    • ECabinet Systems
    • INNERGY
    • Cabinet Pro
