Computer Aided Design
Subject: Re: Mm to imperial in autocad
7/30/20
I pulled a schematic from a fireplace companies website and they drew it in millimeters, but I want to transfer it over to imperial and then copy clip it into my drawing. How do I do this? Thank you very much ahead of time
7/31/20       #2: Mm to imperial in autocad ...
Bud White
Scale the metric drawing by 0.03937
7/31/20       #3: Mm to imperial in autocad ...
Thx. I’ll give that a whirl
7/31/20       #4: Mm to imperial in autocad ...
Bud,
I scaled it down in the .dwg It cAme in as, but then when I copy clipped it /control V into my drawing, it came in way too small.
Also, the drawing scaled down, but the dims stayed large
7/31/20       #5: Mm to imperial in autocad ...
David Wishengrad
Get the book Mastering AutoCAD and read it end to end.
8/5/20       #6: Mm to imperial in autocad ...
Jack  Member
If you google the following "How to convert drawing units from imperial to metric (or vice versa) in AutoCAD", the first result should be the official page from autodesk. Try there first method using the -dwgunits command.
8/5/20       #7: Mm to imperial in autocad ...
dan
You may have more than one scale involved depending on what exactly you are copying.
Zoom in and measure something. It would be relatively simple to scale it back to what you know it should be. Use the reference function. This allows you to select a line (two end points) once you have started the command and by making the line what it should be in mm (36" = 914mm or whatever), the selection will be scaled accordingly. In older versions you may need to enter the reference value but it works the same way.
    • ECabinet Systems
    • CabMaster Software
    • The Millwork Studio
