Computer Aided Design
Subject: Re: older Alphacam
older Alphacam
9/22/20
Ted Member
Website: http://www.audioenhancers.com
I have been running Alpha v6 for many years recently I had to purchase a new computer. The version I have is for a 32 bit processor is there a way run it on a 64 bit? Does anyone have an older version that will run on 64 bit machine.
9/22/20       #2: older Alphacam ...
David Wishengrad
I can't answer that because I don't use alphacam, but a 32bit version should run just fine on a 64bit machine. Does the alphacam installer stop the install? If so, can you extract the installer and then run the extracted files? Is there an ini file that is visible? Also, you can try to contact Longbow software. They made an app for acad that forced 64 bit windows to accept the install and may be able to help you, as it sounds similar.
If nothing else, image the entire drive of the 64 nit machine and run it in a virtualization on windows 10. Vmware, parallels, and similar should let you maintain your working setup on any new modern OS through virtualization.
9/22/20       #3: older Alphacam ...
David Wishengrad
Too many typos... Image the working 32 bit machine and virtualize it on the newer 64 bit machine.
9/22/20       #4: older Alphacam ...
David Wishengrad
That is what you cam use to image your 32 bit. You install it on the 32bit machine and make an image for vmplayer, which needs to ne saved to an external hard drive. Then get vmplayer, which is/was also free, and install it on the 64 bit machine and then load the file on the external hard drive in vmplayer.
It should a actually work slightly faster then before. You will need to read and such, but that's the easiest way I know.
Read this
9/23/20       #5: older Alphacam ...
cabinetmaker
We run Alphacam on an I7 we bought off eBay added some Ram and a graphics card Used HP work station with SSD snd Windows 10 Pro installed. It’s a 64 bit
Make sure all of your updates in windows are run before installing Alphacam
9/23/20       #6: older Alphacam ...
Ted Member
Thank you for your response I have some direction now
3/23/22       #8: older Alphacam ...
LeoLeft
Website: https://www.vinchin.com/en/vmware-backup.html
Not that difficult. With virtual machine, you can run on 64 in just one computer.
    • ECabinet Systems
    • Cabinet Pro
    • INNERGY
