Computer Aided Design
Subject: Re: AlphaCAM nesting
AlphaCAM nesting
3/19/21
Anton  Member
I'm using AC2017r2. On occasion, I need to refer to an old nested project involving many sheets, where I'm required to pluck parts from here and there to separately re-cut. It seems impossible to do this, because the nesting information is retained, mercilessly. Do I have to bust the entire nest of over a hundred parts into separate parts to access three parts with expediency in mind? Seems fairly restrictive, if not prehistoric.
3/22/21       #2: AlphaCAM nesting ...
Snaglpuss
Can't you export from ACAD into a different format and reimport / merge to get rid of native ACAD data. export with dxf or what else can ACAD do? IGES or ??
3/22/21       #3: AlphaCAM nesting ...
Anton  Member
Exporting to another format very likely would not include toolpathing information, though I could of course re-path those lines after re-importation, with the appropriate style.
3/30/21       #4: AlphaCAM nesting ...
David Wishengrad
Barring a better idea, just write a VBA program to export each to an individual file. Let the pc do the work. It shouldn't be too hard.
I don't know why people keep posting in the cad forum. Last ai was over on the CNC forum there were many there that knew much. I suggest you try there before first.
Good luck.
3/31/21       #5: AlphaCAM nesting ...
David Wishengrad
Hey, if you find yourself needing to go down the code route and can give me remote access with the necessary approvals of anyone above you I can take a look and see if you can get the basics up and running for you, no charge. I don't code well, but I understand a bit more than some when it comes to automation. Speaking if automation, a quick search mentioned an automation suite in alphacam. I don't know if you have that functionality in your version. If you do, it's possible the functionality is already very accessable and you didn't know it. Just send me an email if need be. No guarantees.
    • INNERGY
    • Cabinet Pro
    • ECabinet Systems
