Computer Aided Design
Subject: Re: Mozaik Help
Mozaik Help
3/11/22
Brian Heaton
I have been tasked with setting up Mozaik to interface with our CNC Router.an Anderson Exxact. Thankfully this is not going to be a production situation but rather for the owner to tinker with at home and bring projects to work. I got a post from Mozaik but they will have to work on it as it is missing almost everything, no H register calls, Tool change not there, Incorrect tool callout etc. Basic code looks good but this post was marked for an Anderson Exxact Plus which the machine is and I would have thought it would be a lot closer than this as this code will not run I can see that before even taking it to the machine. I also have not found any provision for the drill banks M87 or M88 and no mention of optimized drill drops. I have read a lot of good about Mozaik but honestly I can see it in smaller shops but yu cannot compare it to Microvellum which I have used for the last 15 years. Like going from a Harley to a Vespa both can get the job done,,,,,, But. Just sayin.
3/13/22       #2: Mozaik Help ...
Then get Mozaik to get you a working post?
3/17/22       #3: Mozaik Help ...
Quicktrim
I have an Anderson and Mozaik.
Works flawlessly, just ask for help ,they will help you set it up.
    • INNERGY
    • Cabinet Pro
    • ECabinet Systems
