Computer Aided Design
Subject: Re: AutoCAD 2022 Publish
5/5/22
Not sure why, but when I publish pages, it still wants me to save each page individually. How can I make it where it saves all pages as one PDF? I have a PDF writer installed.
Ty
5/6/22       #2: AutoCAD 2022 Publish ...
Moe
Batch Plot -> publish options -> multi-sheet file
View higher quality, full size image (913 X 367)
5/6/22       #3: AutoCAD 2022 Publish ...
Moe,
Where do i find the batch option in the publish section?
5/9/22       #4: AutoCAD 2022 Publish ...
Can anyone else help me? If what moe is showing is correct, I don’t know where to locate that part in AutoCAD 2022.
5/10/22       #5: AutoCAD 2022 Publish ...
Moe
Sorry for the late reply - the "batch" command should take you to the screen I'm showing. It will list all the layouts that are open and allow you to select the ones you need to publish to pdf.
5/10/22       #6: AutoCAD 2022 Publish ...
Moe
You have to check the box that says multi-sheet file for it to group everything into a single file.
5/10/22       #7: AutoCAD 2022 Publish ...
Moe, this is my screen. The Publush Options is grayed out. If I select the three dots next to it it says select a folder for generated files
5/10/22       #8: AutoCAD 2022 Publish ...
When I select the first page I want to be published and then hit the shift key and hit the bottom page I want it as it being all one entity, then type in a file name for it, it continues to bring up the dialog box to save each and every single page separately.
5/11/22       #9: AutoCAD 2022 Publish ...
Moe
I think I figured out what the difference in our setups is. I think you need to select "publish to PDF" instead of "plotter named in page setup" for it to work the same way I have it.
View higher quality, full size image (412 X 240)
6/15/22       #10: AutoCAD 2022 Publish ...
David Wishengrad
Yeah Moe, that is it. I highly recommend that you use previously saved page setup and then select all your files in that list and right click while hoovering over them, and choose your saved page setup. It will give you the option to import a page setup from another dwg with a browse, but if you have already imported your saved page setup in the page set up manager, then it will be already listed and you can just choose it there. That allows one to assign a new page set up to all of the layouts in one easy step.
Make and save a page setup that works well for you to print to pdf in a cad drawing. Then close that drawing, open a drawing with the same size sheets, and use the page setup manager to import that page set up, but do not assign it to any layouts there. Save your file. Now any time you go to publish it will be on that right-click list when you choose, change page setup, in the publish dialogue box.
    • The Millwork Studio
    • ECabinet Systems
    • CabMaster Software
