Computer Aided Design
Subject: Re: Cabinet Vision DXF Output Missing Functions
2/22/23
Jon Daniel Member
We are currently helping a customer move from beam saw point to point to a nested router. I am looking at the machine we setup to output DXF and am missing a bunch of stuff. Missing operations are dados for backs and drawer bottoms, lockdowel channels, hinge boring, notched toe is missing comes out as a square part. Does any one have any suggestions for where to indicate and turn on these operations?
6/25/23       #3: Cabinet Vision DXF Output Missing F ...
Syed Member
There are many causes which might not generating operations. first check whether you assigned tools for those operations?
7/2/23       #4: Cabinet Vision DXF Output Missing F ...
Kuznechik
99% of missing functions if an issue with the license file. only a handful of times its a runtime error,,
consider a software based license backup,,,
4/26/24       #6: Cabinet Vision DXF Output Missing F ...
murazik
If operations are not being generated, there could be several possible causes. Check that you've assigned the appropriate resources for those tasks before moving further.
11/28/24       #7: Cabinet Vision DXF Output Missing F ...
that's not my neighbor
Website: https://thatsnotmyneighbor.org/
When moving from a beam saw point-to-point setup to a nested router, it's common to run into missing operations in the output DXF files.
    • ECabinet Systems
    • The Millwork Studio
    • CabMaster Software
