Computer Aided Design
Subject: Re: GEOMETERY - DXF - NEEDED
9/18/23
Matt  Member
I'm trying to create a 72" diameter half sphere from 12mm thick material.
The bottom of the sphere I want divided into 30 equal pieces that taper to nothing at the top. I need a dxf flat pattern of the curved part.
If I had inventor I would create a "sheet metal" part to do this.
See attached drawing.
Any Help would be greatly appreciated.
Thanks!
SPHERE.pdf
9/19/23       #2: GEOMETERY - DXF - NEEDED ...
David Wishengrad
In your case, the lengths of the arcs get larger from the top down to 36.
Getting the length of each arc at 1" increments and drawing a point for the first line and then a line for each of the remaining 35 slices ams centering them in order stacked 1" apart will allow you to run a spline up the end points.
As for your thickness, well, that's a 3d edge. Do you want the outside distance or some sort of stretch/compess amount that would be required for any material thickness?
You can probably download a demo of Bricscad and do it with that. It has flattening built in.
9/19/23       #3: GEOMETERY - DXF - NEEDED ...
Matt  Member
Thanks David
I think Im just going to rent Autodesk Inventor for a month and do this myself. The company I currently work for doesnt have a subscription. Thanks for your input
    • The Millwork Studio
    • ECabinet Systems
    • CabMaster Software
